14bff ??
ShiftyK5
Carl Junction, Mo
Are the spring pads spaced different on and 3/4ton and 1ton 14bff?
I thought i saw someone say that a 3/4ton 14bff will bolt right up to a k5 but a 1ton 14bff will not.
tried doin a search on here but couldnt find the answer
would really like to find a 14bff that will bolt right into my K5 without having to reweld spring pads and shock mounts if possible since i will have to find someone to weld them on for me since i have no welder or no real welding experience.
If you own a 69-72 blazer then you need a 1 ton 14ff, if you have a 73-91 blazer then you need a 3/4 ton 14ff.
