Last week I closely checked the pinion housing and saw the outside bearing cage was bent (See 1st photo). Ordered a new bearing and installed it today.
Seems to have made a big difference. The high and low Backlash no longer "moved" teeth. The range I have now is 006 - 009. I'm ok with that.
Did my 1st pattern and it looks good.
Thoughts on the pattern??
ALSO, The pinion carrier has a single steel shim and NO RTV. will the torque on the housing bolts along with the shim effectively Seal it from fluid leaks??
