Gaffed
What parts are required to swap from 8-lugs to 6-lugs on a 14bsf. I don't want to have to buy new wheels if I decide to go through with the swap. Do I just need to find the axles/drum brake set-up off of a 88+ truck and if so is it a direct bolt-on swap? Or will converting it to disc brakes be just as cheap?
I know swapping the outers on the front 10b will be the easiest way to go as far as going 8-lug to 6-lug.
Or just spend the $275 and go to 8-lug wheels?
