So I've finally grown tired of the quirks in the Detroit Locker in my 6 lug 14bsf in my K10. A lot of it is because the K10 is a manual transmission and it does some weird things as a result. I really don't wheel much anymore and the truck is mostly used on the street. I've got a healthy built 350,NV4500,208, 4.10 gears, and 35" tires.
I've been doing some research on what to replace it with and I've come up with a few options:
1. Detroit TrueTrac. Helical gear limited slip so no clutches to wear out but I'm finding a lot of mixed reviews where it's totally grenaded on people or they only get one wheel peals. It's also only rated for 33" tires where I run 35"s.
2. Eaton E Locker. These came factory in the 9.5 14bsf in the H2 and is a bolt in deal for my axle. The only part that doesn't is the retainer for the stator magnet needs to have the bearing cap drilled and tapped. Plus of course the hole to run the wiring. It works like an open dif until you hit the switch and then an electromagnet pushes pins into one of the side gears locking both sides together. Sounds wonderful right? Well I guess a lot of H2 guys that actually wheel go through these like crazy and they don't hold up well to shock loading. They also unlock and relock when you change direction. So going from forward to reverse like rocking yourself out of a hole could blow it to pieces. They have their downfalls but I guess if I drove with them in mind I'd maybe be okay?
3. Traditional clutch type limited slip. Tried and true concept. If I find it's letting one wheel spin more than the other I can get stiffer springs for it so it locks harder but then it'd wear out faster, though they are rebuild able. If you choose this option let me know which brand you'd recommend. (Auburn/Eaton/etc)
I know ARB is also a great option but I don't want the added complexity of air compressors or the price tag that comes with it.
