14BSF swap : brake line fitment
G-Force8
DFW, Texas
I have a 14BSF 8 lug rear axle out of a 91 2wd 2500 pickup that I'm probably slinging under my '91 1500 Suburban. I got the 14BSF complete with all brakelines. Will they work with my suburbans' brake line geometry? I know the 14BSF'ers that were under the ''84-91 3/4 ton Burbs will bolt right up,but I don't know if the "new body" style truck brake line setup will interchange with the older body style trucks
Kind of curious myself. You have the "new" style brake lines on your Suburban for the old body style, I would be a bit surprised if they changed the setup...I believe they are still run essentially the same way.
Worst case, you get cables off of one in the wrecking yard.
*hijack...your avatar is freakin hilarious! fight club!
