14FF axle swap Qs
ace138
The colony
Can I use the emergency brake cables off of my 10 bolt for the 14 FF bolt?
Can I run 15 “rims on a 14bolt with stock drum brakes?
What is the Napa part number for the conversion ujoint?
Specs on the rig 1988 k5/305/700r/NP208
You can run 15 in rims with no problem on the 14 bolt. The front will need grinding if you run 8 lug.
I dont have the part # on the top of my head but the joint converts an S44 joint to 1350. A good parts house should be able to cross it.
My 10 bolt cables didnt work.
My cables worked on my '90 going to a '85 14b. The cables go down the drivers side and the passanger side brake crosses over the axle.
