Masiony
what is the housing made out of, steel or iron?
how sure are you?Nodular (?) iron.
I thought the pumpkin was cast iron and the tubes were mild.
Harley
but cast what? iron or steel?I know factory are cast, and aftermarket (Like Dynatrac) are nodular.
But either way they're iron.
!i need to plate the bottom.What do you need to weld to it? You can weld to cast iron if you do it right with the right welding rods and procedure. Rene (TRusty) would be able to give you good insite on it I bet.
I have welded to mine with a flux core Mig welder. Nothing super structural but it is holding sofar.
Harley
I'd agree with Ductile cast. Cast Iron (grey) would crack like a sumbitch. Flux Core or MIG should do just fine.
Rene
so not too hijack or anything but how about the knuckles and Cs on a 44 and 60 I welded a steering arm onto a 44 knuckle that had all three studs broke, I just didn't know they were broke the weld was for insurance but ended up holding it on for a couple years so I assume ductile iron on those too.
