DavidB
Anyone tried this?
DRW D70 and DRW C&C 14FF share the same bearing hubs. No differences between them.I want to use a DRW D70 and be narrower. IIRC it's 73"...so I would end up about 69" or something with the C&C "narrower" hubs.
um yes you can...
i put the 14 bolt srw hubs on my drw dana 70 to make it wider...
So I could use the SRW to make mine narrower![]()
your forgetting that a stock srw d70 and 14b are both 69 already. D70's and drw 14b hubs are the SAME hub. you will end up with a 73" wide d70 if you put c&c hubs on it.
