I started this last weekend, pretty much wrapped up the install this weekend. I didn't plan on doing this for a while longer, but something was screwing up in the rear brakes on the SF so I pushed it up. I was planning on running the stock drum brakes for a while, then upgrading sometime later until I opened up the FF and found the brake drums were toast. It was cheaper to convert to disc brakes than buy new drums.
I pulled apart the bearing hubs, cleaned everything and greased the wheel bearings before re-installing with new seals. I still need to build a small tab to hold the end of the rubber brake hose.
