14ff disc swap questions
wayne
3/4 ton status
Carlisle, Pa
I'm getting ready to swap disc on the 14 bolt. I will be running a set of Caddy calipers which I already have. I just need to get the springs and levers for them. I need to have the e brake and I am not going to put one on the driveshaft/t case. As far as the lug nut studs is there ones that fit better then the stock ones? Where are some of the best write ups with part numbers?
You'll just have to take the assembly down to local parts store and see which ones fit best. I had same problem when I bought my rear disk brake kit from Boyce. The studs they sent didnt fit as tightly as I thought they should. I took it down and found the perfect fit after trying 5 or 6 different sized studs.
