14FF housing tube diameter?
four_by_ken
Allenton, MI
Could anyone tell me the diameter of a 14FF housing tube?
Thanks
Ken H.
'86 K5 in parts
1-ton 454 44 TSLs
I can tell you my SemiFloater is 31/2". Does that help?
<a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
Eye-ball with a ruller shows just under 3.5"
Russ
85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
The axle tube diameter is 3 3/8" for the 14 bolt FF.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
Hopefully this helps. BDS lists for a 77-87 3/4 ton 4x4 (which houses a 14FF rear) rear ubolts....P/N 040032, Diameter is 5/8", Width is 3 5/8", length is 10", and they are the round style.
See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
I second what Rene said. 3 3/8" is the diameter of the tubes.
I will bet you a million dollars that it IS that measurement.
<font color=red>Only real men drive K30's!!!</font color=red>
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
I called the dealer and told em what I had. 1979 K20 pickup Corp 14. They told me it was 3 1/2. Does the year make a difference?
SK-15
J**P...it's whats for dinner!
Roads? Where we're going, we don't need any roads!
If it wasn't for bad luck I would have no luck at all!!
I'll add another measurement of 3-3/8" to that tally....that's what I measured off my 14BFF.
I cut a 3-3/8" hole template for new spring pad mounts and it fits perfectly. Not too tight, and not too loose.
-Greg72
'72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
<font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
Why do I have this feeling that the parts boy at the dealer was smoking something funky?
SK-15
Ok, I did what I should have done the first time. I took a pair of "C" jaw vise grips and tightened them down till they would drag just a little back and forth across the tube, then measured the opening. 3 3/8" exactly. When I "eye-balled" it earlier, it looked like just under 3.5 but just over 3.375. Obviously it was an "optical conclusion
Russ
<blockquote><font class="small">In reply to:</font><hr>
<hr></blockquote>
Because he was and he does not give a crap what the actual true diameter is. He just wants you to leave him alone so he can concentrate on getting his BUZZ!!!
Russ, you mean 3 3/8", not 2 3/8".
Of course, that's what I said... You should read more carefully... {rolling eyes up to ceiling and whistling casually}
Russ
And why does Leadfoot say
"Diameter is 5/8", Width is 3 5/8", length is 10"
3 5/8?!?!?!
Argh!! Cornfused!!!
And WHERE do you get some size like that?!? I went all over, NAPA, CarQuest, AutoZone, etc and NO ONE has 5/8, 3 3,8 or 3 5/8 and 10 long!!! Where do you people get these at? I don't want to buy them from the dealer for $20 EACH!!
SK-15
Go to Farm and Fleet, thats where I got mine. The 5/8" is the diameter, the width between the 2 legs should be 3 3/8" and the length should be about 10".
<a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
Where are you measuring "between" the legs? From the middle of the post to the middle of the other post? Or from inside of the post to inside of the other post? Or from outside to outside?
I did not see at F&amp;F anything labeled 5/8 3 3/8 and 10". I found a 9/16 one that was close....but not the 5/8 that this axle is gonna need!!
Thanks
SK-15
Look in the yellow pages for a spring company.
I got mine for $10 ea.
<font color=green> Too bad ignorance isn't painful </font color=green>
I measured from inside to inside.
I got mine at the F&amp;F here in Urbana when I did my swap. I dont think mine were that long though. I did the shackle flip on the rear so I just measured from the inside of the rounded end to the tip of the legs. (I want to say about 6 inches but Im not positive on that. )
I can look at my reciepts, it might list the part # or something.
Another thing, If you look at the back of the package they have a list of all the sizes or how to order what you want.
