14ff hub assemlbe prt#
olbattlebuggy
Registered Member
Cleveland, Ohio
does anyone happen to know the part store #'s for the hub assembly on the corp 14blt ff? I converted to rear disc but want to throw new hub with bearings and seals on to be thorough.
i also need the napa part number for the dually studs
any help would be appreciated,,
thanks fellas:wink1:
There's no reason to replace the hub unless there's something wrong with it.
Also why do you want dually studs? When doing the disc conversion you re-use the stock studs (as long as your 14ff had the 13" brakes). Sometimes you need to machine the heads of the studs to 1" OD so they fit in the recess of the rotor.
