Cajun4x4
the 5.13 gears are great except for some whining under deceleration due to probable non-spec pinion bearing preload. the axle is dripping fluid from the splines of the pinion around the nut {note: not the seal} and im thinking its because the nut isnt tight enough not letting the thrust washer stop the oil which would also affect said bearing preload... thoughts?
as for my brakes, I installed this fancy new MC that muddybuddy had installed in his k5, on his all he had to do was mount it up and roll on... on mine I lost 2/3 to 3/4 of my original pedal stroke and the pedal is firm as $hit, so firm I dont think I could realy slam them if I wanted to making braking a tad scetchy at the moment, however it is still very managable, and I do also have around 1000 lbs in the bed of my truck. the brakes also dont seem to be letting go quite as fast as they used to. im still running the stock ifs brakes up front at the moment... hoping this will be cured when i swap the 10blt front in... thoughts?
