I want to switch from a strap style rear yoke on my 14ff to a U bolt style. I have the yoke, do I need a shop to do this?
Just swap it. Yes there is a crush sleeve, yes you can replace it, yes a crush sleeve eliminator kit is a thing, yes a shop could do it for you. I have swapped several over the years when I needed different u joint sizes or damaged a yoke and have never had an issue.I want to switch from a strap style rear yoke on my 14ff to a U bolt style. I have the yoke, do I need a shop to do this?
I did that on a Wagoneer. Seemed to be fine.I drilled my yoke out and used u bolts where the straps used to be
