Drew, whether you actually need the Moser shafts will depend entirely up to you as to whether you want to spend the cash on them.
As of today, I still have not seen one 14FF shaft fail from breakage or misuse. I have not even seen one where the splines got twisted.
I have seen the spiders go bad on open and Gov-Locked carriers. But still no bad shaft or anything.
I would say the Moser shafts are the last step you would need to do in order to upgrade and beef your 14FF. The stock shafts are already "overkill" from the factory with 1 1/2" diameter shafts. 30 splines is close to 35, so, they are still stronger than most people think. /forums/images/icons/wink.gif
BTW, while most people (not CK5!) think the D60 rear is more stronger and bulletproof than the 14FF, they fail to realize that the 14FF is more comparable to the D70 instead.
I won't even talk about a D60 rear. I have seen those go bad just as easily as a 10 and 12 bolt rear. /forums/images/icons/tongue.gif
