15" rim and 14bolt ff discs do i need to grind?
i had to kiss my calipers with a grinder, but nothing like my 60 calipers. Back spacing is 4.25 and i'm using ruffstuff brackets. hope that helps.
Not to hijack the thread but I am :haha:, with that 4.25" back spacing would a 16" rim have fit without a problem?
Ive got diy4x brackets w/ 15X10s and 4.25 bs, no grinding for me:D
the front on the other hand took lots of :grind:
Brackets and calipers will need to be ground down. Go slow and bolt the wheel on. Look at the angle of the wheel. The brackets and caliper need to be ground at this angle. Start with new pads or when you install new pads you may have to grind more.
