15" wheel , 14BFF fitment
G-Force8
DFW, Texas
If I decide to go ahead and use the '76 k20 axles I have, will a 15" wheel fit over the drum brakes on the 14BFF?
yes, but if u decide to do discbrake conversion, u could be grinding the calipers depending on the backspacing
cool,thanks. I will be buying some BFG KM2's at truckfest in a couple weeks and wanted to go 15's for more sidewall.
worked just fine on mine. i used keystone white wagon wheels. like 4.25 backspacing i think. 15x8
i have 15x10 eatons on my m1008 14b ff.....3 3/8 back spacing.....fit perfectly
here she is......
...1984 m1008....they stick out an inch in the rear and almost 2 in the front...
Short answer: Yes :)
I'm running 15 x 8 with only 2.5 inch backspacing (to clear the calipers on the front) but the back clears no problem even with more backspacing.
