Just got a call from Baitfish1. He came over and spent the weekend deer hunting at my place. Left this morning headed home.
2015 Nissan 4wd pickup. Most of the trip was on I10 at speed.
Noticed the truck acted squirrelly when he tried to turn into the driveway. Discovered he drove the entire distance, about 150 miles, in 4Hi.
I talked him through getting it to shift by backing up with the control knob in 2Hi until it clunked. He wanted to know what to do next.
I don't have much of a clue. He is totally non-mechanical. In fact, he has the almost magical ability to suck the mechanical ability of otherwise good wrenchers just by standing close by.
I suggested that he take it to a shop and get the transfer case lube changed, and the U-Joints checked for looseness.
Also park it on dry concrete tonight and look for leaks tomorrow.
I have had this conversation with folks here before. Running the kind of hardware you run, 60's or Rockwells, 203 or 205 cases, and 1440 U-Joints, you are not bothered too much about running in 4Hi on pavement.
All it causes with yours is some tire scrub.
But I have seen factory aluminum transfer cases grenade at boat ramps when the driver put it in 4Hi to pull up a slick ramp, then left it in when he made a sharp turn on dry pavement.
Not sure what Nissan uses for a transfer case, but I'll bet its not in the 205 class. He is running standard size tires, so that had to help.
The whole truck is stock, no lift or oversize tires.
Anybody got any ideas about suggestions to tell the poor guy? If I had the truck over here, I would crawl under and look for cracks, mount damage, and probably change the fluid in both axles and the transfer case just for fun.
To add to the fun, he is scheduled to drive it over here next weekend and haul his 25 foot camper to our hunting camp with it.
Anybody know what kind of running gear it has? I don't think I have ever been under it.
All suggestions welcome.
