Mike83
Im wondering if a 8 lug 15in rim will clear the brake caliper front and drum brake on a D44 front and Corp 14bff rear axle, they off a 79 3/4 ton burb. 15x10 8 lug
If you figure your back spacing correctly and they are not powder coated they should fit with no grindage but thats my 2 cents.
Ok thanks that should make it easier, ive been thinking the standard 2in backspacing, maybe 2.75in i would rather grind a bit more than replace bearing all the time
