broncoman6524
Basically will it fit? I found a set of 37 IROKs radials for $600 almost new, I can get 15x12 steel wheels for $75 each through work.
I did some poking around (avery's 3/4 swap thread
) And it said they will not fit with-out grinding and or less that 2.5 inches of backspacing.
My question would be where exaclty do they hit? If I got reverse mount wheels with 4.25" of backspacing I *should* be more than fine correct?
Thanks....
Chris
) And it said they will not fit with-out grinding and or less that 2.5 inches of backspacing.My question would be where exaclty do they hit? If I got reverse mount wheels with 4.25" of backspacing I *should* be more than fine correct?
Thanks....
Chris
