15x10's whats the widest tire?
I've seen 44x18s on them no problem. I have 40x15 on mine.
I know from running tires from Super Swamper they will suggest the rim size for the tire. Running a tire too wide/narrow for your rim size will cause the tire to wear improperly, but if that isnt a concern you usually <from my experience> can run what ever fits. I'm currently running a 19.5" wide tire on a 15x10 rim with Zero problems. Im able to run a low air pressure without problems<yet>
holy #$%^ are you joking i just want a wider sixe for the bush wacker cut-outs so it will fill the back tire out i want good tire wear becasue is 60% street truck
