Seadub
Registered Member
This is a set of factory aluminum 6 lug 15x7 wheels that were made by Enkei in Japan. The clear coat has been removed from all 4 wheels, and the oxidation has been sanded off of 2 of them. The sanded wheels need to be polished out. The other two wheels still need sanding and polishing, or you could remachine the entire set if you want the machined finish. I was going to sand down the other 2 and polish them all out but ran across a great deal on a set that was already done. $150 - I live in the DFW area.
