15x8 vs. 15x10
91 Jimmy
Registered Member
Michigan
Someone school me on 15x8 vs. 15x10 rim sizes. I am going to be running a 33x12.5 tire. Which one is better? Do most rims use stock backspacing unless otherwise stated?
i have 2 sets of rims i like the 10 in ones better, made the tires look bigger, and the stance wider, but then again backspacing played a role in that.
The tire will run taller and narrower on a skinny rim. If you run them on a wider rim, they will run shorter and wider.
Martin
i like 15x8 better myself on a 12.5 inch tire.it peotects the rim more and i think looks better.i have standard bs also for said reasons.
