16.5" dually wheel question
thatK30guy
1 ton status
Between GM and Dodge wheels, both are pretty much the same wheel?
Hub bore same size?
GM uses a ring that sits on the wheel while held by lug nuts and Dodge has tapered holes for the lug nuts?
Any pro's and con's to using one over the other?
dodge axle hub possible clearance counter bore for the dodge tapper seat of the rim / lug nut position . been long time since I seen one around here to recall 100%
little of both .
the special lug nuts that help center the rims up on the flare of the lug nut holes could interfere with flat hub face on gm stuff. if I recall as I said dodge has cut out to clear these flares in the lug nut holes.
I'm not comfortable with Dodge wheels then. Think I will keep looking for the GM wheels with that ring that sits on them. Tried and true I guess and experienced, too.
