16" wheels clear calipers?
TJ1978
I have MANY questions
East Valley, Arizona
I like the look of these wheels and I know 16" isn't ideal but better than 16.5 I've seen.
Will 16x8 clear the brake calipers on 3/4 axles? I know with 15" you have to shave quit a bit off the caliper.
These do sell these wheels in 17" the size I have now but... new ones are $255 a wheel, looking for a cheaper way to get these wheels.
You can run what, 35x12.5 on these or?
Check out this item on OfferUp. https://offerup.co/OI5TfuRuDCb
16s were factory from the mid 80s till mid 2000s before they went to 17s…should fit fine
Outlaw 2's do look good. The first set will tuck in your tires a bit, depending on what you have now.
I have 17x9 with 35x12.5x17
I'm thinking I can get 35's again
I've read 12.5 will work good with 8" rim
Go 35x12.5x16
They do make these is 17's but each wheel is $255 but if I get new Outlaws I could same money on tires and have my preset ones remounted... I may go that route, still deciding
:DI have 17x9 with 35x12.5x17
Go 35x12.5x16
Wait a minute, your supposed to buy those 16s so I can buy your old tires and wheels. Cheap:waytogo::D
