17" rims
freakdave
austin, tx
Looking at a set of 17" Centerline Convo with 265/70R17 for my stock lift K5. How would these 17" rims look compared to say 32" tires with 15" rims.
"Stock lift"?
I have switched from 265/75R16's to 265/70R17's (i got a deal on teh wheels/tires), and they don't look bad. The larger rim looks good on a DD, but the tires are still small and will look smaller due to teh smaller sidewall height.
IN terms of rim selection, i think the Convo style is better off left at 16 or even 15" size. Of course its personal preference, but there are a LOT of other wheels i like better if you are going to go with a 17" size.
Um, i forget. The first set of 17's i ran were stock 2002 Avalance 17x7.5 rims. I can't remember teh backspacing. THe ones i have now are 17x8, with very close to stock backspacing. Remember i have a 94 IFS truck though, not sure if yours is an older one.
If i remember correctly though, stock backspacing is like 4 7/8" or somethign in that ballpark......normally greater than most aftermarket rims.
go look at a dodge or ford diesel from the past couple years. same tires. they dont look bad, lil narrow and a lil shorter.
Grant
