83blazer
Memphis,TN
a guy i know is selling an old chevy pick up it has a 10 inch lift on it and i was wondering if that could fit on my k5 i looked it looks similar underneath but I didn’t know if maybe they made the pick ups different I always assumed they were the same
if it is a 73-87 half or 3/4 ton truck, it will bolt right in your 83
IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
Brian is right, it will bolt in..............BUT there are other considerations for a 10" lift, including but not limited to (lawyerese speak
) steering arm change.........driveshaft length...........pinion angles............shock length..............plus you then will need new wheels and tires to make it look hot! Good luck......
<font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.alloffroad.com>www.blazzinor.alloffroad.com</a>
oh that jokers got 44incj tsls and i think 15x12inch rims and a bumper that just screams to have a winch put in
