1952 GMC COE fuel tank location advice
Jake52CabOver
Newbie
Hey guys, I'd like to get some input regarding the gas tank location on my 52 GMC cab over. It has a mid-engine setup with a corvette transaxle (4L60E) directly bolted to an 8.1l Vortec. The independent rear suspension is from a 2004 Ford Expedition.
20140725_132930-jpg.3492678
I'm using a 40 gallon tank from a 2005 Ford Excursion because I'm feeding a very thirsty 8.1l, the fuel pump assembly can be easily upgraded for higher flow and so that I can brag about having a 40 gallon gas tank!
I'm 90% sure I'll be mounting it UNDER the cab for the following reasons;
  • I don't have enough room for a large gas tank behind the rear axle due to bed length
  • The safest location for a gas tank is in FRONT of the rear axle and between the framerails (we all remember the pinto) according to the research I've done.
  • Mounting under the cab would provide the best weight distribution for 250 lbs of fuel.
  • The Excursion tank has a wrap-around 1/8" skidplate that goes about 1/2 way up all sides. It has reinforcing ribs and weighs about 80lbs. The thing is stout.
The reasons why I'm concerned about putting it there are;
  • the tank would be close to electronics (possible ignition source)
  • the tank would be close to the front of the engine (heat source)
  • fumes may become trapped under the cab (possible emergency cab ejection source:D:biggrin:)
The reasons why I will probably ignore those concerns are;
  • electronics and electrical components are typically well sealed as is the fuel system. Tank vents will be routed high under the hood.
  • I'm planning a sheet metal heat shield between the tank and engine
  • modern tanks are designed to be mounted under the cab/cabin of most vehicles. Practically all SUVs have them under the cabin.
Please let me know your thoughts. Here are some pics.
20170423_115117-jpg.3515457
20170423_115123-jpg.3515460
Definitely cool project.
Without mounting a tank in the bed, probably the best option
And /\ he's right. More pictures!
Looking closer at the pics.
It looks like a custom tank is probably in order for this thing.
Just kind of hard to see. Buy based on the other things I probably wouldn't worry about placement.
