Gunfreak25
Registered Member
Well I joined so I could post up my project but it seems I am limited to a 5 post count rule before I can post pictures or anywhere else on the forum. So let me give the details on the project, then you guys can ask questions for me to reply to until I hit 5 posts! Then I should be able to post pictures.
1954 GMC M211
13,000lbs
6 wheel drive
9.00x20 Military NDCC (40")
6.17 axles
Original Tcase 1.16:1 high range only
Np231 in front of original transfer for 2.72 low range
1992 K case 700r4
6.2 Non turbo HMMWV motor
4 core Chevelle radiator
10 blade HMMWV fan. No clutch, constant drive for maximum cooling in AZ!
22,000lb rated transmission cooler
7.3 IDI fuel filter bowl modified to work with 6.2L.
24v original in tank fuel pump.
Air over hydraulic brakes.
York 210 compressor used for air pressure.
Air conditioning in the works
1954 GMC M211
13,000lbs
6 wheel drive
6.17 axles
1992 K case 700r4
