This is how I got home today. It backfired pretty hard, and was a bear to restart. When it did start it didn't seem like it was firing on all cylinders. Did I mention that the backfire started a small fire in the carb? I had to hit it with a small fire extinguisher blast. That was more excitement that I needed. Truck has been running rough for a while, I'm guessing I need my carb rebuilt. So I'll throw in all the factors for a better diagnosis.
1. I've been running without an air cleaner for a couple days, I can't find the right size locally go figure. A new threaded stud in the carb fixes that I guess.
2. The truck bogs down when I lay into the throttle, it sputters and will die if I stay into it.
3. Old gas maybe I had some old gas [6 months old] laying around, mixed that with some new gas and put that in Sunday
4. Exhaust leak, it backfires through the muffles when running, especially when I let off the gas suddenly
5. Cooling, been fighting this since I got the truck, I'm running a 165 degree thermostat it normally stays around 190 but will spike to 220 ish in traffic.
- it needs a shroud and larger fan.
Yeah that's one hell of a list, the fire didn't damage anything. I kept the blast small to avoid getting that white power everywhere. What should I be focusing on? Bad gas, exhaust leak, carb, cooling?
This all happened a couple hours ago, it fires right up when its cool.
thanks!
thanks!
dude, just saw this thread and it reminded me I owe you a pm.
