manlikegorilla
Registered Member
As far as I can tell theres alot of diffrent ways to convert sm465 to nv4500.
Here is the run down of my project.
3/4ton axle swap maybe by end of summer.
Replacing 4" lift 33x12.5 swampers to 8" lift 38x12.5' tsl sx's
Replacing wore out 350 with a vortec 383 stroker hyd roller cam with a FAST ez injection. Engine is built & ready to install while getting ready to install the engine I thought a 5 speed w/a hyd clutch would be sweet, so I started doing a little research. And I'm as confused now as before.
I picked up a gm pre 96 nv4500 for 4x4 minus bellhousing that needs gone thru for $100
I have 2 np205's 1 is coupled to a th350 & the other is coupled to sm465 both in good condition.
looking for some input from someone whos done this swap in this vintage truck. what they did & what they maybe would have done diffrent, part #'s??? best place to buy the parts??? would all be sweet.
I was told that this is "THE PLACE" to find what I need.
"BUILDING A BETTER BEAST"
