1969 K5 - Disc brakes in the front / drum in the rear.
Been fighting a problem w/ my brakes for a while. Used the opportunity to replace the calipers and brakes up front. (OEM AC Delco) Ordered new hoses but they were too short. They probabaly need to be replaced, but aren’t cracked and don't appear to be leaking. I'm using a brake bleeder/vacuum pump to bleed the brakes.
* Passenger front doesn't want to bleed - I can build pressure w/ the pump but no more than 15-20 lbs. It leaks down moderate to fairly quick. Just enough time to open / close the bleeder screw
* Drivers side seems to bleed fine. It builds 20+ lbs and slowly leaks down. More than enough time to open / close the bleeder as needed
4 month ago I also replaced my carb. For reasons I can't remember I also replaced the vacuum hard line. This would be the screw in hardline that goes from the back of the carb over to the master cylinder booster.
There is a very small hint of brakes if you stand on the pedal. The pedal feels normal & not spongy. Drove it around today in my pasture, and based on the tire marks - the driver’s side front is working based on the skid marks.
What do I need to be looking at?
