1AAuto.com
1970 - 1986 Chevy K10 Truck Ball Joint LOWER PAIR (MOOG K8195T)
This Moog brand replacement Lower ball joint PAIR is just what you need to insure the safety and integrity of your vehicle's suspension and steering.
Specifications:
Comes as a PAIR
Fits both the LH (Driver) & RH (Passenger side) FRONT LOWER
Fits into knuckles or Lower control arms depending on application
Direct replacements
Built to strict quality control standards
Correct for 4WD models only
Worn ball joints can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace loose or worn ball joints with our quality replacement.
One way to diagnose a loose, or warn ball joint, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint for play, if it is moving you probably need to replace it.
1A Auto Offers FREE SHIPPING on all orders
Specifications:
Comes as a PAIR
Direct replacements
