Fighting a low speed buck again. I added a 37 squirter, from the 31 it had and moved the pink cam to hole 2 (which is wrong according to the chart). I will likely drill a 25 to .035 after work and go to the blue cam. It helped the acceleration buck above 2000 but the deceleration is BAD.
Current timing:
22 deg initial at 950 rpm
38 total (initial + mech @ 3200)
9 deg of vac advance (limited the total opening but it is fully open at the 11in/hg it has at idle)
so it has 31 deg at idle (initial + vac)
I am sure it is timing related but not sure how to attack it right now.
38 is probably a bit high with the chambers it has and I likely should go back to 36 total which will make the initial 20 but I can add more vac advance.
The 9 extra deg of vac does make the idle better. I would ASS-U-ME it would idle awesome locked out at 36 but I am afraid it will ping with the stick. Plus the starter isn't awesome so I need to replace that too.
I may will pull the vac advance for the trip home to see what that changes.
Current timing:
