1972 chev 4x4
360hookman
Newbie
Fairfield Ca.
ok its time for this truck to go to someone thats gonna love it as much as I did in the day...the drive train has ben completely rebuilt starting with a bbcfrom the oil pan to water punp and radiator
block is a 454 bore 2bolt main w/427 crank all ballanced and blueprinted
peanut heads with roller tip rockers big push rods and a strong rv cam
air gap manifold
msd pro billet dizzy w/6a box
carter afb carb I think its a 650 e/choke
edelbrock alum water pump 4 core radiator all new rubber mounts top and bottom
the correct wire harness for the big block with left side alt
TRANS
nv4500 with 5TH gear correction and 1st gen 1st gear w/np241 tc I liked this combo for the low range and hassel free in/out of low range and direct bolt on adapption
hydro clutch w/center force duel friction and billet fly wheel
DRIVE LINES
hy-angle built heavy wall rear with 1410 at each end
front is a 1350 cv w/1410 at the axle 22' of travel...
AXELS
front is a dana 60 4:10 great working limited slip fresh carrier bearings fresh rotors and pads and wheel bearings fresh knuckels
rear is a 14bff 4:10 gov lock works great fresh drums and shoes and an e break that works and holds!!!
STEERING
psc pump and ported box with off road designs hy steer/xross over...ball joints
SUSPENSION
sky jacker soft ride 6" at all corners w/rs9000 shocks ord heavy shackels up front
all new rubber cab mounts
all new rubber floor mat and peddal pads
beanch seat has fresh foam and cover
dash has never ben cut for a stereo
no teach or tilt wheel
a/c cab a/c not hooked up
long bed has factory tool box in the right side and bed is good and straight tail gate opens and cloeses with one hand
I built this truck thinkin that I'd keep it for ever...since my divorce I think of orther toys and no longer use this truck and it needs to go to a good home
the truck is in fairfield Ca 94533
5500 bucks sound fair to me.......call scott at 707 580 7834
I can email pics and ill be adding pics soon gotta figure it out
You just need to get to 5 posts before the site allows you to post them. As a paying member, padding for 4 more posts to get there is OK.
wow this is crazy 25 bucks just to bs about our favorite hobbies and oh by the way gotta waste more time just to put some pics up????
I can email you anyone my pic album at any time,this I can do with no problem....
The 5 post minimum is to eliminate the spam bots that come on here posting links for viagra or other crap...
goinn back to school.....just feel like I've out grown the truck....if and when I take it out for a spin I fall back in love and Ill drive it for a week and with all the scare tissue and ache's and pains in the body,I soon remember why I dont love the truck anymore...my new love is the classic V-DRIVE boat scene and typical maintenance on a boat is ssssooooo much easier on the knees and back,man I'm to the point that I build a scaffold around the front of the truck just to change the oil!!!Im a crane operator and after a day of stompin an break pedal's.....the last think I want to do is jump in and out of a lifted truck.
I have a bunch of pics at picasa.com I dont know how to embed the link here or tell you how to find me to view the page where the pics are....but if I had a EMAIL address I can send the folder to anyone from the picasa site...that I can do!!!
Cant wait to see this thing. Im interested.
