BUDDY
I never thought it would come to this, but it looks like I'm going to have to let the blazer go.
It is a 1972 Chevrolet Blazer
Pretty much stock, but I have done a lot of work on it. However, most of that work was done about 8 years ago or earlier.
TH350 NP205 D44 front 12 bolt rear - 3.73 gears
Mostly done, new aftermarket electrical harness.
www.americanautowire.com
3" body lift
I replaced the entire rear bed floor with 1/8" diamond plate steel & installed a storage box just behind where a center console would be. Once that was all, in I had the entire interior lined with a tan Permatech liner.
It seems to have rusted quite a bit being in WNY for the last eight years, but it's mostly the doors & rockers. I was never concerned about that because I was just going to cut them out & put in rock slider 2x6, 8 rectangular tubing. The door skins should be replaced.
I have several pictures of it on cardomain if you'd like to check it out.
http://www.cardomain.com/ride/2529968
HOWEVER, the top is NOT the pop-up camper top anymore. It's just a stock hardtop. It needs just a little work, but is very solid.
PM me if you'd like to see it in person.
Thanks,
Buddy
3" body lift
Thanks,
Buddy
