I replaced both calipers in my chevy van years ago for naught--it turned out to be the old original rubber brake hoses were the cause of the brakes dragging...it doesn't take much,once the brakes drag for a few miles,it can heat up the brake fluid enough to the point the free play at the master cylinder gets taken up,and then the brakes self-apply...
My van drove me nuts last year--I had let it sit over 10 years,and decided to pull it out of its resting spot and start fixing it up,in case I had to put it back on the road,should my truck fail..
I went to step on the brakes,and the pedal was "stuck"--after pushing harder,I felt it break free,and the brakes applied..then after moving it,a steel line going to the rear brakes popped from rust,and the pedal went right to the floor..(as can be expected!)--I replaced the whole line from the junction block up front to the rear end at the rubber brake hose,then attempted to bleed the system...
I had to pump the pedal like 20 times to get it to pump up--then as soon as I let off and pushed it down again,it would go right to the floor,with zero resistance..seeing the master cylinder was "seized" at first,I figured it had ripped the little rubber seals inside on the piston--so I went and bought a rebuilt master cylinder (only $20 at Autozone,to my surprise)..
After installing that,I had the exact same issue..and NO fluid was coming out of the rear wheel cylinders...even after removing the bleeders !..
After much confusion,I decided to take the new line I made up off at the rear brake hose on the diff--fluid squirted all over me,so I knew it was getting that far--then I took the rubber hose off,and found out it was plugged up tight,I couldn't get 125 psi of air from my compressor to blow thru it,nor shove a wire thru it..it was completely sealed up..
After I put a new hose on it,I had the brakes bled in like 10 minutes,after fighting with it for 2 days...(and I think the master cylinder was still good,but for $20 I did not mind replacing it,after it sat so long)...
