tchp
Registered Member
I have a 1972 K5 4x4 with a 307 and 3-Speed manual column shift. I replaced my starter today, and noticed that in addition to the mounting holes for the 3-bolt mount flange that my current starter uses, there also appear to be two additional, unused holes tapped into the block up above, which might correspond to the bolt pattern for the other type of starter Chevy trucks use that has two vertically oriented mount bolts. Does anyone know if you can use either of the two starter types on my engine? I only ask because about 10 years ago a mechanic broke one of the tapped holes in my engine block that my current starter uses, so I am down to using only 2 of the 3 bolts for the mounting flange (which at least has worked ok for the past decade, but if I could use the other type of starter mount that would be a good thing). TIA
) drill the hole out to a slightly larger size, tap it, then put in an insert which is threaded inside and out; the outer threads matches the new hole, and the inside threads match the bolt for it.
missed that part. Nemmind...
