1973-80 Behind Bumper Winch Mounts now available
Engineered Vintage
IGOR
Vendor
Damascus, OR
Been working on this one too long. These launched in January
The STRONGEST kit on the market for these trucks.
No other kit mounts to your truck frame in 14 place (with option for 16!) in as many places and reinforces the steering box area as well as the stock front cross-member.
I see you also have one for later squares... how does it fit with an existing ORD steering box frame repair and reinforcement kits?
It has no interference with the weld on frame repair kit. It does replace the small tab on the crossmember from the ORD bolt on kit, and does not affect the large triangulation bracket from the ORD kit.
See the top left corner of the photo for where it bolts to the steering box. This is on my '84.
It has no interference with the weld on frame repair kit. It does replace the small tab on the crossmember from the ORD bolt on kit, and does not affect the large triangulation bracket from the ORD kit. View attachment 401818
Dan - I need to put you on the payroll! :)
