JW-Tex
Registered Member
One of the three nuts on my fiberglass top used to secure the top to the windshield header is loose and spinning. Any idea the best way to repair or replace one of these nuts?
If you drill out the rivets will it slide out through the sloted hole (i do not think it would)?
the only solution I can think of is to cut an access panel from the outside of the top and then drill out the rivets and remove the cage and put a new nut in it and repair the cage. Reinstall the cage and rivet in place and fibergalss patch the the panel back into the top.
Any suggestions appreciated!
