JKitzmiller
Registered Member
Up for sale is my 73 chevy blazer. The drive train is complete and don't have time to finish the body due to another baby on the way. The entire front clip panels are all new, just needs aligned. I have the bumpers and front grill, just not on. Below are the specs for the vehicle. Blazer has been garage kept.
Runs. Sounds fricken awesome!
$6500+ in all new parts, $4000 just in the motor.
Asking $2500 obo. All reasonable offers entertained. In addition, the blazer is locally advertised. I can possibly make shipping arrangements from Morgantown, WV.
Contact me by PM w/ telephone number if want to talk.
Engine
1984 Chevy 350 4bolt main
bored 0.030 over
dipped and fluxed, w/ new plugs (documented)
World SR Heads, 67cc, 1.5/1.94
Balanced Rotating Assembly professionally done w/documentation
Holley 670CFM Str. Avenger 4brl Carb
Holley Str. Dominator Intake Manifold
Comp. Cam w/ Hydraulic Lifters (0.47lift) (280 series)
Proform Roller Rockers (1.5ratio/3/8”)
Proform 5/16 pushrods
Cloyes timing chain and gears
180deg Hi-per thermo
high-vol oil pump
MSD Ignition HE-175
New 6.75" balancer
All new Clevite bearings
4 Row Radiator
Grade 8 bolts throughout
Dress Kit
All components listed and those not mentioned (belts, hoses, starter, etc) are all new
Remaining Drive Train
SM465, 4 speed trans, new seals bearings and inspected
NP205 Transfer Case, new seals and inspected
3:73 gears, 12 bolt
all new seals and Timken bearings throughout drive train
new U-joints
new clutch plate
Others
new rear light wiring harness
new fuel and brake lines
rebuilt steering box
new hubs
new rear brake assembly
new tie-rods
engine compartment and frame painted
Body
all new panels for front clip, needs aligned
rear panels with little rust and front floor pans need replaced
front window frame has dent
new body mounts
Engine
bored 0.030 over
high-vol oil pump
MSD Ignition HE-175
New 6.75" balancer
4 Row Radiator
Dress Kit
3:73 gears, 12 bolt
new U-joints
new clutch plate
Others
new hubs
new tie-rods
Body
new body mounts
