mikekwesell
Registered Member
I all, I have a 1973 CK5 that is running but that needs a bunch of work all around... cold use some input on the following - thank you in advance and much appreciated!!
1. Can you recommend a disc brake conversion kit mfg for the rear wheels? Drums are not functioning... I figure better to swap out.
2. I put 36" wheels and tires on it, do I need to get the front and rear differentials reconfigured? (Do I need different/new ones or can I have the ones that are currently on there serviced to accommodate the new wheels and tires)
3.What would you say is the ideal carburetor for this vehicle? I has the 350 small block.
4. Windows in both doors - mechanisms to roll up/down windows are kaput. Need to replace. Is it possible to buy new guts for both doors so windows will function properly?
THANK YOU!!! (still learning how to use this site - apologies if this is posted elsewhere / multiple posts)
