I bought a 1 ton thats too nice to swap parts off of so frank has to go.
1973 K20 (3/4 ton) 8200gvw
Front dana 44 with flat top knuckles that allow for a cross over and high steer. New pads and longer brake lines. 4.10 gears. Comes with a new ez locker that may be broke be will come with spider gears to replace it. New mile marker lockouts.
Rear 14 bolt ff 4.10 gears, new wheel cylinders, axle seals, and shoes.
Truck is lifted 4" spring and block.
New master cylinder.
Body is very rough but would make good parts for a 1/2 to 3/4 swap or trail truck. A/c cab with full gauges
Th350 that works great but unknown miles flushed 50 miles or less ago.
205 transfercase, 27spline. Works great. resealed front output shaft.
The cool thing about this transfercase is with a shaft from ord you can put it behind a 700r4 and keep your overdrive but have one of the toughest transfer cases ever produced.
I had swapped in a 454 but I am keeping that. I do have the 73 350 yet but really prefer to sell the truck with no motor but will include all brackets, alternator, a/c compressor, ps pump and radiator (heavy 3 core).
700 obo. Negotiate if engine is wanted.
