Selling my 1974 K10. I spent about 10 years frame off resto/modding it.
Dana 60 crossover steering 4.10 open
14BFF with disc brakes 4.10 open
NEW stainless steel brake lines
driveshafts are new
40 gallon tank in the rear.
350 SBC with Tuned Port Injection flat top pistons, cammed, ect. TPI has all new sensors, ect.
TH400 from Jasper with 3 year, 100,000 mile warranty installed in september (torque Converter failed on my last one)
4"lift DIY4X shackle flip
NEW Warn vr8000 (i believe) hidden in front bumper.
procomp ES9000 shocks
corbeau bucket seats
remote start viper alarm.
New dash pad, door panels, handles, weatherstrip ect.
great sound system. Pioneer with JBL speakers, custom box. single din that opens to a 7" screen. I need to look it all up but it has 2 3", 4 6" and a 10-12" sub with a killer amp in it.
5 nearly new BFG AT 315/70/16 on Black MT classic lock wheels
2015 Tahoe center console
white paint is about 5 years old
undercoated and bedlined after all rust removed. bodywork done.
Basically everything in it is new or nearly new with about 6,000 miles since finished.
The bad or needs :
Tcase has two new forks in it but 4H is very difficult to impossible to lock in. 4L works great. 2H works great. I was going to twin stick it to see if it fixed it but haven't gotten around to it. FIX PENDING 11/9
Speedo is bad. I might have that fixed before it sells. I need to find one. Factory tach and other gauges fine. FIX PENDING
I have all the AC stuff new just not installed. Hoses, Condenser, evaporator, ect.
the COLD/HOT climate control box is hard to switch back and forth. It works just difficult to move. It is hard locating another for a 74 that matches.
Steering wheel needs pulled off and set straight. Just a detail. The trucks alignment is fine. FIX PENDING
Center Console needs officially mounted down. It just sits in there currently.
Needs new glove box insert. Have not found a AC cab one i can use yet. I cut up the other one to hold the computer.
Comes with:
extra spare harness from a friends 73. In case this one goes bad.
spare 74 steering column with tilt in case that goes bad.
all the new AC stuff.
Any paperwork for warranties for any parts.
I would like $16,000 for it. I would also like it to go to someone on here since it belonged to my dad who passed when I was younger. I don't think I would have ever built it without the info i learned from here.
The truck is a little dirty in the pics and the door dent is not show in these pics I will get it washed and post some fresh ones this weekend. I will also get some engine bay pics up as well.
driveshafts are new
The bad or needs :
Comes with:
