bridgeguy
Registered Member
As I have removed all the body molding from my K-5, I have no use for it anymore. It is the dual level (row around the top beltline and another lower) molding and I have, I believe, most, if not all of the pieces. I say that only as I started removing it around 5 years ago, got sidetracked by life and have recently started working on it again.
This includes the panel across the tailgate which has the "Chevrolet" emblem as well. I have most (but not all) of the mounting screws, speed nuts, etc. and have labeled (again) most but not all of the molding as to its location. These are (for the most part) in really good condition with the black still really defined, the tailgate piece does not appear to have any dents at all, etc. I did take my time removing them and it was NOT a "pull until it comes off" event. They were actually removed very carefully and the fastening hardware re-installed on the piece with the piece being labeled on the back with either masking tape or Sharpie(tm).
Basically, if you want it and you can't pick it up locally, then you pay actual shipping (I have NO idea what that would be but it is all packaged as shown in the photos). If you can pick it up locally and can actually use it, come and get it. If it sticks around here it will only get destroyed over time and I would rather have someone from coloradok5 have it and need it.
I live in South Oroville (for those in the know, east of Palermo) and work in Marysville so can meet up with someone if that helps out.
If this brings good will, then great. If you have an odd or end that might be useful that you would like to trade, great but not necessary.
I have photos and will attempt to add them but may have to shrink them a bit and apparently figure out where to put them so that everyone can access them so it might be an hour or a day to get that all ironed out.
Let me know if there is a particular piece you are looking for but would prefer someone to take the whole lot.
