Howdy!
Well this is somewhat a mess but just so you guys know I'm 19 and this will eventually be my first blazer and build. I'm a bit confused on what type of path to take this beauty on, so I was looking to see what some of you guys could suggest.
The K5 is a 74' with a 91' body so in order to make it a 74' again I'm aware that I would need to change quite a few things body wise (Every panel from what I've researched). It also had a Cummins stuck in it by the previous owner but the swap was not done very well and they didn't box the frame beforehand so I have to re-do the swap and box the frame. The Blazer sat for at least 2-3 years with intake off so the engine should definitely be torn down and rebuilt because who knows what was living in there. It also has a 3/4 ton GM 10 bolt in the front and a 14 bolt in the rear.
To make a long story short, I want to get the chassis nice (box, POR-15, new brake lines, etc..), convert the body panels to a 74 (I could salvage the drivers door and drivers bedside possibly, do the full top conversion, rebuild the engine, and paint it the classic two-tone (I am aware of all the little things as well) . This option should get me to around hopefully 2 years and under $10k. I want to be able to enjoy and drive it.
My father suggests I go 110% and bring it to the point of a show truck and try to get "all the money for it" because it's a 74'. My predictions with that route is it'll take me to about $20k in work (not including labor) and probably almost a decade of time seeing how every project I've seen that in-depth takes absolutely forever to build.
I know a show quality 74' restomod is worth $40k - $30k but for how long it would take and the amount of cash I can't justify it.
I know this was more so a rant lol but what would do you guys suggest? Are 74's really worth going all the way on?
