leverhead
Registered Member
Hello. Long time browser...first post. I have a 75 blazer i've been working on for a while. Chassis and drivetrain all done and getting ready for initial startup.
Attempted to introduce some fuel via gas cans and as I was filling, the fuel would trickle into the tank but after a short period would spill out the filler.
Checked the venting ...all is good there. Then I noticed that the rubber hose that connects the filler tube to the tank spout angles up a bit as it connects to the tank.
So it looks like it inclines (iow, the tank spout is higher than the filler tube) which makes the fuel more diffucult to get to the tank. Compared to the original, the repo tank
looks identical. So it seems fuel could be pushed thru with pressure via a gas pump but a tank pour is an issue.
Tried lowering the tank via the straps which improved a bit (the remaining fuel in the hose trickled in)....so question:
Is there supposed to be a downward angle from the fill tube to the tank? Any pics i can find just look horizontal so hard to tell...
Has anyone shimmed the tank dowrn to get this angle?
Is this just a factory quirk?
Thanks.
Thanks.
