1975 bumper onto 1985 frame?
Would a 1975 bumper fit a 1985?
Just asking as I have a minty 1975 grill guard to put on, but '75 and '85 bumper profiles are slightly different.
Do I just need to put the 1975 bumper braces onto the 1985 and then bolt on the '75 bumper?
https://www.lmctruck.com/1973-87-chevy-gmc/front-bumper/cc-1973-80-front-bumper
It's not a quick bolt on solution but yes you can do it using the brackets from the 75 but you need to make something to bolt the middle line of bolts as they bolted to the frame curve.
The newer frame is open channel
44...thanks for the info. I was not aware of the frame differences. I'll look for a local early style bumper and start cobbling! Thanks.
its easier for a 73-80 frame to be modded for 81-up bumper than backwards . if you can fab decent it wont be to hard .
The '75 bumper will bolt right up to the '85 center brackets, but shims are needed on the lower bolts so the bumper will sit level. The 70's outer mounts will need to be used.
