1976 Cadi ebrake calipers, flex lines, pads sale or trade
84400
Registered Member
Northern MA
-1976 Elderado E brake calipers with springs and levers
-Flexabble Stainless hoses (short style)
-Brand new set of special nub pads (never mounted)
One of the calipers has a torn seal. The seal kits are under 10 dollars if you want to rebuild it yourself or use it as a core. Calipers have been "shaved" for 15 inch wheels.
I bought these for my 14 bolt swap but instead am going with a driveline ebrake from TSM.
$125.00 plus the ride (will fit in a flat rate box)
Will do trade plus cash for:
DIY4X poly motor mount kit
ORD sway bar disco's
May trade straight across for other parts / 6.2 diesel parts.
pictures avalible on request.
be willing to sell just the pads, springs and levers?
If not i may be interested in the calipers too.
I might depending on your offer. The core charge on cadi calipers is real high. Something like 75 bucks!
would you also want the stainless braided flex lines? Shipping would most likely be cheap since you are fairly close to me.
Yea i know the cores are wicked high, i have some calipers but i dont have the springs or levers.
I dont need the braided lines, all i would be interested in are the pads, levers and springs. PM me how much you are looking for ballpark.
Also if its possible could you put a picture up? or at least text me one 518-429-7336, of the levers and how they attach to the calipers. thanks
Picture added to the first post. The caliper towards the bottom is the one needing the seal replaced and has the arm and spring off in the picture.
Wage92 your first in line but I have another guy interested in the whole setup. Let me know if you want the whole deal or not. I would rather sell as a lot.
