Hey everyone.
Yes, its time for me to sell the rig. Its time for someone else to take ownership of it and use it more than I've been able to. I've got $26,000+ into this rig (parts + original price).
Here is the "short story" of this truck’s specifications:
1976 Chevy K10 “Scottsdale” short bed
Thanks for checking it out! You can also see more pics and videos in my CK5 album.
- GM Dana 60 1 ton front axle. Open differential. 4:56 ring and pinion. Warn Premium Locking Hubs
- GM Corporate 14-bolt Full Floating rear axle, Detroit Locker, 4.56 ring and pinion, disc brakes
- SBC 350 engine with mild RV cam, Edelbrock Performer Intake Manifold, Sean Murphy Industries (SMI) Rochester Quadrajet carburetor, Hooker Comp full-length headers. All AC Delco ignition parts.
- GM “Muncie” SM465 4-speed manual transmission mated to a completely rebuilt NP241C transfer case with Slip Yoke Eliminator (converted from TH350 and NP203)
- Custom front High Angle Driveline with 1410 u-joints throughout (even the CV uses 1410 joints).
- Custom rear driveshaft by Rocky Mountain Driveline, with 1350 CV and 1410 u-joint at the rear axle.
- Custom built flatbed with wood floor.
- Crossover Steering with PSC Hydraulic Assist system.
- Suspension lift is approx. 9” via DIY4X B52 brackets and 52” springs in the front, and 56” springs in the rear with Offroad Design Shackle Flip. Bilstein shocks at all 4 corners.
- Offroad Design Crossover Steering
- PSC Hydraulic Assist steering
- Polyurethane suspension bushings, engine, transmission, and body mounts throughout the entire truck
- Viair Onboard Air System
- Pitbull Rocker Radial 41.5x13.50R17 tires mounted on 17x9 Raceline Monster aluminum beadlock wheels
- Warn VR 10,000 lb. winch (without a single pull on it)
- Single 31 gallon K5 Blazer gas tank that replaces the problematic stock dual 16 gallon tanks
